- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 & EAX80 reach
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX80 & EAX80 reach
Hi NetGear Community
I have a need to get wifi coverage in my shed, located some 25 m from my house. I recently upgraded my router to a Nighthawk RAX80 in the house (double brick wall and steel roof) as well as installed a Nighthawk Extender EAX80 under the roof in the shed (made of steel). The purpose was to have a seamless mesh connection when moving between the shed and the house.
Now, the 2.4 GHz connects fine but not the 5 GHz and the router link LED on the extender shows amber, indicating a week connection. I am unable to locate the router or the extender closer together so that the 5 GHz band would work satisfactorily. Will another similar extender somewhere in the middle solve the problem; i.e. can a mesh extender reach the primary wifi router via another extender? Or is there another, more reliable option available?
I'm not sure if a powerline wifi extender will work as we have a Tesla solar battery installed that already talks to my power supplier over the powerlines.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 & EAX80 reach
The issue is the brick and the metal. They are literally the 2 best blockers of wifi.
2.4ghz broadcasts further and through more materials which is probably why it connects. Which frankly I'm impressed by. Usually brick/metal are good enough that signal is pretty much worthless on the other side of it.
The powerline might be an option.
Or a MoCa adapter if you have coax ran out there.
Or you could just run an ethernet wire from home----garage and connect the eax80 to it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm fully aware of the steel and brick constraints and I can't run wires to connect the extender in the shed; hence my question of whether another extender somewhere in the middle might allow the one in the shed to reach the 5 gHz range.
@plemans wrote:The issue is the brick and the metal. They are literally the 2 best blockers of wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It might help, it might not. Tough to say 100%. Like I said, usually brick and metal combine to make signal unusable. So will adding one in the middle help? maybe.
Or you coud go with a set of point to point adapters (see netgear airbridge).
