×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX80 and iTunes server support
mr396
Follower
How do I enable the RAX80 to be able to be an itunes server? I can not find the check box to activate it in the advanced setting under Media server tab under USB functions.
any help?
Message 1 of 3
Re: RAX80 and iTunes server support
Do you know that it supports this feature?
There is support for the RAX80, including a manual, at the end of this link:
>>> RAX80 | Product | Support | NETGEAR<<<
The manual says nothing about iTunes.
See the section Specify ReadyDLNA Media Server Settings.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
JoseAndres041
Luminary
I don't think it supports that. It's not listed in this KB.
https://kb.netgear.com/29924/Enabling-the-iTunes-Server-feature-on-a-Nighthawk-router
Message 3 of 3
Discussion stats
  • 2 replies
  • 2784 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
