- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 regularly disconnects devices, then they reconnect
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently “upgraded” from an R8000 thinking I would have better connectivity and faster speeds. Since purchasing the RAX80 I continually have devices drop their connection at random, then they reconnect within a minute or so. It is very aggravating when streaming tv and/or trying to connect to a web page. I have the latest firmware version installed and it continues to happen. I’ve rebooted many times but nothing works. I have been reluctant to do a factory reset. Anyone else have this issue or have a solution?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
My experience with this problem is slightly different. In my case, the RAX80 simply slows a specific (random) system's connection down to a crawl. Rebooting the system dows nothing to fix this. The only fix I've found so far is to reboot the router and problem is gone.
Tech support has suggested changing the MTU setting to 1468. (Advanced>setup>Wan Setup) So far, I haven't noticed any improvement from this.
So they made another suggestion I haven't had the opportunity to check out yet. Here it is:
">>click on advanced on the top of the page
>>Then Select Advanced Setup
>>under Advanced Setup click on Advanced Wireless setting
under Wireless Advanced Settings (2.4GHz b/g/n) under Fragmentation Length (256-2346): changed the number 2346 to 2300
for CTS/RTS Threshold (1-2347): change the number from 2347 to 2301
do the same for Wireless Advanced Settings (5GHz a/n/ac)
Hit apply.
After this please observe the connection at least six hours."
Perhaps this is worth a try. I have some other problems with this box. If they can't resolve them, I'g going to ask NetGear to buy the RAX80 back or replace it with something that is stable enough to actually work correctly. - My own optinion is that they shouldn't be messing with public domain code to run this box, generally, this has too many glitches and security issues. - You'd think they could afford to have professionals writing the firmware for these systems.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 regularly disconnects devices, then they reconnect
You are experiencing one of the many bugs with the latest firmware version 1.0.1.58. Best suggestion is to downgrade to the previous version 1.0.1.56
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion! I’ll try backing it down and see if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be weary! From what I can tell, Sam the Gam is the only one who seems to have little to no problems running *.56 firmware.
I had to downgrade to *.40 because .56 is a crap show.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's the thread with all the .56 woes:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the additional info. I kept getting a failure trying to load .56. For now I stayed on .58 but I turned off Smart Connect. Turning that off seems to have helped tremendously. I'm going to watch it and see how things go. Worst case is I go back to my R8000 and wait until Netgear figures out its firmware issues 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello allarone - I'm interested in the issue you're reporting. Looking forward to your next update!
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
What are some known issues with .40? I am having the same issues as this post and decided to downgrade to .40, but dont want to start turning on QoS and MU-MIMO and smart connect if those are buggy. Even though I would love all of those features
- Mark as New
- Bookmark
- Subscribe
- Permalink
.40 still will experience intermittent disconnects, but definitely not at the frequency of .56 and .58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a little over a week with Smart Connect shut off it has been quite stable. I had an Amazon Echo drop its connection once, but other than that things have been great!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using 1.0.1.56 because I feel it is slightly faster then 1.0.1.40 on DFS Channel (108) 5 Ghz Wifi band with Wireless AC devices.
And even when I downgrade to 1.0.1.40 under the GUI version it still said 1.0.1.56 for GUI version but firmware version 1.0.1.40. I did not experience disconnects with 1.0.1.56 only with 1.0.1.58.
However, I have MU-MIMO, AX WIRELESS, Beam Forming turned on. I am not using Smart Connect and QOS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
you off MU-MIMO and keep the AX , then it is ok, I have the same issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dragonpak wrote:you off MU-MIMO and keep the AX , then it is ok, I have the same issue
I upgraded to the latest version 1.0.1.64 and started to experience random devices disconnecting mainly ethernet devices. I did not experience this issue on 1.0.1.56. I just disabled MU-MIMO and hope this issue is resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even with MU-MIMO disabled the WAN / LAN still randomly disconnect / reconnect throughout the day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
once you upgraded, did you hard switch it off and on again? the netgear software is very stupid, it is not hotswap
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dragonpak wrote:once you upgraded, did you hard switch it off and on again? the netgear software is very stupid, it is not hotswap
After I upgraded and turned off MU-MIMO the router reset and when it came back up I turned it off and unplugged then plug and turn on again. I went back to firmware 1.0.1.56 where I did not experience the issue. I had a 60 day uptime without any issues with the 1.0.1.56 version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently picked up an RAX80, replacing an X8 (R8500). After updating it to the latest firmware, and getting it all set up to drop in and replace my X8, I find out how bad this router really is. I am very well versed with Netgear routers having used and owned previous an AC1450, R6250, R6700, and X4, and X8. All of these worked very well for me, as each was purchased as an upgrade to the next. This new RAX80 is by far the worst I have ever purchased. First time through setting it all up, had it up and running, and about an hour later, it reset itself and lost all settings back to factory settings. So then I spend another hour getting it set up again, and it seems to run very well. Go to bed, get up in the morning and all internal connections are lost and Wi-Fi signal is nonexistent. Reset, and same thing happens next day/night. Go back checked all settings and made a few small tweaks, and was running extremely well once more. Go to bed, next morning everything is disconnected again. Having my home set up with HA, it's important that my router is stable and working without this type of thing happening. So for now, I have a large very expensive paperweight, until Netgear does something to fix it. All of my previously routers ran for months with the need to be rebooted, this thing can make it 12hrs. Netgear please address this. This is the biggest piece of garbage I have ever had from you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@cliff344 Probably saying 'welcome to the club' is the wrong statement here. It's not a club you want to be in =(
For me personally, I'm running on an older firmware version and aside from missed security updates, and my VPN acting strangely, my router is mostly stable. You might try downgrading and see if you get stability there. I don't even know what the latest is anymore these days...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
cliff344,
Thanks for taking the time to post your experience. I'd like to ask if you've been able to get in contact with our support team. If not, please send me a message with your contact info and serial number.
Looking forward to working with you!
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with cliff344 - I've used Netgear for decades and they have always been rock solid - until the RAX80. The wireless connectivity has always been the bane of this wireless router, and it took 2 WEEKS of tech support call to stabilize it when I first got it. The router was most stable with ver RAX80-V1.0.1.58_1.0.24, but it appears that the changes to RAX80-V1.0.1.62_1.0.26 totally borked it.
Where I once had a stable wireless network, I now get DAILY COMPLAINTS on drops (which I myself have enjoyed). I am tempted to roll back to 1.58, but given the fact that this is an outward facing firewall for my home, I am hessitant due to the security bugs that were fixed with this release.
I suspect that the changes to the Beaconing and DMT could be the culprit, but I can't confirm becuase I can't even tweak those settings on this router!
Netgear, please fix this issue ASAP, or the RAX will be the last Netgear product I will ever purchase - let alone recommend to others. Please help everyone on this thread to be your advocate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've always read reviews on products where I was having similar problems and either fixed it from comments, waited until a fix was coming, or just lived with it. However this is a much different case because house runs on wifi and more importantly my home security. So this is my first time ever writing a review. I'm having constant disconnects and I have to admit to my wife that I bought something that's a piece of crap. Giving her the chance to say I told you not to buy it. I"ve always bought Netgear routers because they have always been stable and reliabile which made me happy. This is my first chance wanting to buy top of the line router ($300+) and I fell stupid. Please fix this issue. I don't care if you have to disable a few features, but at least make the connection stable.
