× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 setup as access point some devices don't see SSID
Ronr2
RAX80 setup as access point some devices don't see SSID.  Iphones or pads see and can connect to the SSID (either 2.4 or 5), but printer and IP cameras don't see SSID (either speed).  Printer and cameras can connect to the main router but have poor connection due to distance. Any thoughts or suggestions?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: RAX80 setup as access point some devices don't see SSID
Hi Ronr2 - Have you gotten a chance to change the wireless channels on your router?
Page 64 of the user manual: http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
~Christian
Message 2 of 3
Ronr2
I'm not sure why changing channels would matter since some devices can access the WiFi not.  Two of the devices that cannot are 802.11n, but the documentation says the RAX80 is n compatable.  I'm not where I can access the router right now, but I wanted to understand the logic of changing channels.
Thanks for the suggestion.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2435 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
