Orbi WiFi 7 RBE973
Reply
RAXE300 5GHz Keeps dropping on broadcast and slow
chrisc13
Guide
RAXE300 - Firmware Version 1.0.8.64
5g keeps dropping out (2.4g is always okay. )
I tried different channels but still the same problem.
Upgraded firmware twice,
went back 1 version of firmware.
Factory reset
Same issue after a few days of use.
I have scanned the wifi band 5g around me with a mobile app and selected none crowded channels.
Devices to 2.4g and have no problems but limited to slow download speeds and so buying a £350 router for high speed 5g and 6 has been a waste of money for me so far.
Any help appreciated -
( my old R7000  was solid for years and i regret spending all this money now which i did as I work from home and tried improve the network for my work and my kids )
thanks
Message 1 of 12
Accepted Solutions
Guru
Re: RAXE300 5GHz Keeps dropping on broadcast and slow
set your speeds at "up to 2400mbps".
When its set for "up to 4800mbps" it has to be 160hz wide and that uses the dfs channels.
If something is broadcasting on those channels, they have to switch off them and that can cause drops when it does so.
If you're in an area with DFS, I'd avoid those channels for stability.
Message 9 of 12
All Replies
chrisc13
Guide
Setup:
All separate SSIDs for bands 2,5 + 6 , all broadcast
Enable 20/40/ MHz Coex - not selected
No Guest networks
No A security activated
No QoS
OFDMA on for 2.5 + 5
Message 2 of 12
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 3 of 12
chrisc13
Guide
Many thanks for the quick reply , my first post here . Appreciate the move for me . Thanks
Message 4 of 12
Guru
What actual channel do you have selected for the 5ghz?
Make sure to avoid any dfs channels as you can get drops if there's radar in your area.
Its only the 5ghz? 2.4 and 6ghz are fine?
Message 5 of 12
chrisc13
Guide
thank for the reply ,
Its only 5GH and channel = 06 , mode up to 600Mps
2.5 + 6 appear to be fine
Message 6 of 12
There is no Channel 06 on 5GHz. That's 2.4 GHz.
5GHz runs from 36 upwards.
Message 7 of 12
chrisc13
Guide
sorry about that ,(  working and trying to reply at the same time )
Channel 44 -
as screenshot
Message 8 of 12
Guru
Message 9 of 12
chrisc13
Guide
oh many thanks for the info , thats great to know ill give it try . thankyou
Message 10 of 12
chrisc13
Guide
My connection has been stable since this so looks to have fixed my issues , many thanks for the support
Message 11 of 12
Guru
Glad you got it stable. Must have some dfs channels broadcasting in your area.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2779 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
