× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAXE300 and RAXE500 internet lights
NetSond
Star
I’m looking to purchase a RAXE300 or RAXE500, I’m wanting to
Know if the internet light flashes when there is traffic flowing. Also does the WiFi and Ethernet lights flash the same way? I have the RAX70 which does this but don’t want to buy one and find out that it doesn’t
Thanks
Message 1 of 16
NetSond
Star
Re: RAXE300 and RAXE500 internet lights
Thanks for the reply, In the past I’ve noticed that the manual says something and the product does something else, so wanted someone who has one of these to test it for me
Thanks again
Message 2 of 16
Guru
https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/RAXE500-LEDs-not-blinking-using-the-2-...
Thanks again
Message 3 of 16
Guru
why are you wanting this feature?
Thats what I'm curious about?
I generally don't choose a router based on whether a led blinks or not. Especially when they're different specs, performance, and price.
Message 4 of 16
NetSond
Star
Thanks for the replies
I’ve found that link useful, RAXE500 doesn’t blink when traffic passes
Just now need to find how RAXE300 behaves
I want to find out as I want to know if my connection is getting pinged and also I’m used to this feature as previous routers had this
Thanks again
Message 5 of 16
NetSond
Star
Is this router not popular, I thought id ask the question on the forum instead of buying one and finding out, just don’t want to waste money
Message 6 of 16
Guru
Recent FW update has a few items missing or broke. NG has been made aware of it and said to put a fix forth in next FW update. I've enjoyed mine and works well. Have to find what works best for your needs and such. Always recommend trying something out and if it's doesn't work, return it. Find good places that have good refund policies. Like amazon.
Good Luck.
Message 7 of 16
NetSond
Star
Hi thanks for your reply
Very helpful that the router works well. Could you tell me if the internet light flashed before, and does it still flash with the recent firmware
Thanks again
Message 8 of 16
Guru
Internet LED doesn't blink.
No idea why different models have differences. Most of the time I guess, not really needed, As long as the color is WHITE and your seeing GOOD status on the routers web page, seems to be enough. I know some people are visual. I am but, also, I'm not looking at the router all the time so, as long as it's working, I'm good. 😉
Message 9 of 16
NetSond
Star
We are talking about the RAXE300?
Did it ever flash on previous firmwares?
Thanks again
Message 10 of 16
Guru
RAXE500. RAXE300 should same as it should same code base.
I could have. I've only had my RAXE500 for about 2 years.
Something you could do, install a small non managed Gb switch in between the host ISP service device and the RAX router. Don't connect anything else do this switch accept the ISP modem and the RAXE router. Then you'd have some LED indication. Could install a semi managed or managed switch here and let the switch help log any oddities or network traffic issues if you really wanna dive in.
Message 11 of 16
NetSond
Star
Hi thanks for the reply
Im hoping someone with the RAXE300 will reply but your idea is very good, i may try that with one of my old routers and see how that works
Thanks again
Message 12 of 16
Guru
Maybe @nuteksystems can help on the 300 router.
Message 13 of 16
NetSond
Star
I’ve just DM’d them
Thanks, if I get a DM then I will post what I have learned so that it helps others
Message 14 of 16
Guru
Message 15 of 16
NetSond
Star
I can’t believe no one has the answer
Message 16 of 16
Top Contributors
Discussion stats
  • 15 replies
  • 1786 views
  • 6 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
