- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAXE300 slow ReadySHARE USB SSD speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
just got the RAXE300 and generally i think that it is a great router and i like the WiFi 6E speeds. My PC is connected to the router (Intel AX210) with 2402/1922 (Mbps) speeds which is nice!
The only issue which i have with the router are the really slow ReadySHARE USB C speeds. I only get about 37mb/s write speeds from my PC to the drive over the network, which is really slow. My old router (Nighthawk XR500) got around 60mb/s.
I expected quite a lot better speeds from this router and that is why i chosen it, but instead it is even slower then a 5 years old hardware (XR500) even when it supposedly has superior hardware over that router.
I use the attached SSD to the router as a NAS so i expect it to have good speeds.
Any idea what the issue here is? Why are the USB speeds of the RAXE300 so slow? Is this a flawed design, a software issue or maybe just a configuration issue from my side
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAXE300 slow ReadySHARE USB SSD speeds
what format is it in?
Have you tried a different usb device?
I don't have a RAXE300 but my RAXE500 gets around 80-100mbps on my usb based ssd. Its just a generic enclosure with a sata 2 drive from an old computer.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is formatted with NTFS. I have tried with two different devices (SSD and HDD), with no change. With both USB devices I get above 60mb/s on the old XR500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry, I don't have an RAXE300 to compare speeds with. I did find a review from Dongknows that had usb issues as well as it was only connecting at usb 2.0 speeds.
https://dongknows.com/netgear-nighthawk-raxe300-wi-fi-6e-router-review/
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RAXE300 also. I just attached a drive configured the same way and mine is pretty much the same speed. Could be a firmware problem I hope.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mean could this be an issue with the new USB controller which is obviously used on this router for the USB-C?
Also interestingly when i copy data from the USB drive network share to my PC, then the speeds go up to 90MB/s, which is what i would also expect from the write speeds. So i guess this is only a write issue?
During the copy process from my PC to the USB drive, i saw that the routers CPU load was just up to 8% so the CPU load should not be the issue here. The RAM usage during the copy on the other hand was 490MB/512MB, so this is quite at the limit.
I also hope that this is a firmware issue, as such speeds are honestly not acceptable nowadays, especially when 5 years older and lower trier hardware was performing better...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @wildwestman @CallPaul ,
Did you use a Type C to USB 3.0/2.0 adapter HDD or just use a Type C HDD ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you share more details like,
1. What's your HDD/ SSD brand ?
2. What kind of connected interface it is? TypeC/ USB3.0/ HSB2.0 ?
3. When you transfer the file from PC to readyshare, did you also running other application or playing the games ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My main USB SSD for storage is a Crucial X8 2TB drive. It is USB type C. I have tried two other USB drivers, one HDD and another SSD with the same result. So it is not a specific USB drive issue.
No, i did not run any other applications or games but that honestly does not matter. I am doing the exact same 1:1 scenarios as I used with the XR500 where i got over 60mb/s.
The interesting this is is that copying data to the PC from the readyshare drive, i get 90mb/s which is what i would expect.
Another thing is that when i change to the 6GHz network, even that the link speeds 2402/2402(Mbps) reported by windows look better then on the 5GHz network, the write speed drops to around 30mb/s which is even worse.
User | Count |
11 | |
8 | |
6 | |
3 | |
3 |
