× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
RAXE500 - 2.4 Ghz and 6 Ghz RSSI fluctuations standing next to the router
coolwifi
Tutor
The 2.4 Ghz and 6 Ghz wifi RSSI seem to fluctuate a bit, with 6 Ghz fluctuating more sometimes up to +/- 10 dbm even standing next to the router. Looks like both the 2.4 and 6 Ghz band antennae are in the right wing of the router. Changing the channels didn't help Is the router defective? Got this router in a deal for 271 bucks and thinking of returning it.
Also the latest firmware causes inconsistent latency spikes in both wired and wireless connections to the router. I had to downgrade the firmware to prevent this latency issue. Is it wiser to get the RS series instead?
Message 1 of 6
Accepted Solutions
Guru
Re: RAXE500 - 2.4 Ghz and 6 Ghz RSSI fluctuations standing next to the router
Its normal. someone has already written an article on it so I'll link to the article versus re-writing it.
https://www.beaconzone.co.uk/blog/why-is-there-variation-of-rssi/
Message 2 of 6
All Replies
Guru
Message 2 of 6
coolwifi
Tutor
I looked at the same article before. the 5 Ghz RSSI doesn't vary much, may be +/- 2 dbm next to the router. The large fluctuation only happens in the 2.4 and 6 Ghz band RSSI. Is there anything defective with the right wing antennae of the router?
Message 3 of 6
coolwifi
Tutor
@plemans Do you think that 5-10 dbm variation in RSSI standing next to the router is normal in the 6 Ghz band? The 6 Ghz band is barely useable in this router unless you are in line of sight of the router within 10-15 ft.
Message 4 of 6
Guru
If you feel its an issue with the device, feel free to open a support case with netgear if its in warranty. If its new, sometimes its faster to exchange it where you bought it
Message 5 of 6
coolwifi
Tutor
Thank you, will see if I can return for an exchange or get the RS series instead.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 663 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
