Orbi WiFi 7 RBE973
Reply
RAXE500 showing three CPU cores not four
Killhippie
Prodigy
I just noticed that when I scroll down using router information using the current 1.2.13.100 release the firmware only shows three cores active on my RAXE500, anyone else seeing this  or have I lost a core?
CPU LoadingCPU1: 0.30%  CPU2: 0.19%
CPU3: 0.29%
Message 1 of 7
Accepted Solutions
Guru
Re: RAXE500 showing three CPU cores not four
if you log into the debug page, what does it show?
the debug page is the IP address for the router plus /debug.htm
so if you're 192.168.1.1/debug.htm
Message 2 of 7
All Replies
Guru
Message 2 of 7
Topology
Virtuoso
@Killhippie, I am also seeing three CPU cores listed for my RAXE500 (1.2.13.100)....
Message 3 of 7
Finkellmann
If I use debug I see 4 CPU
Message 4 of 7
Retired_Member
Not applicable
a picture's worth a thousand words.
Message 5 of 7
Finkellmann
Message 6 of 7
Razor512
Prodigy
It is a weird but with that firmware version, on the advanced page, it will show 3 cores while the debug page, it will show the CPU usage of all 4 cores.
The issue is purely a web UI one where it is failing to poll the 4th core when the page is loaded.
With that in mind the device is making full use of each core. though to really see how it distributes tasks to each core, you will need to give it a heavy workload such as connecting 2 external hard drives, and writing files to both while also doing a simultaneous upload and download throughput test between a system on the WAN side and LAN side of the router, while the armor service is active, while also performing a speed test between wired and wireless clients on each WiFi band, At that point, you may see a number of the cores hit around 40-50% usage.
So far I have not found a way to get a higher CPU load under the stock firmware (also using the latest firmware).
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1430 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi 770 Series
