- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAXE500 web page wont load security
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a RAXE500 when I click on security-access control, the web site does not load then stops responding and kicks me out. I have to restart the router because it becomes extremely slow after this, any thoughts?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, v1.0.7.68 broke the Access Control List but it has been fixed in the next firmware. Sorry, I'm not privvy to when that will be released, but hopefully it's not too much longer.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAXE500 web page wont load security
I just gave it shot on mine and it worked fine. I tried on both edge and google chrome.
How many devices do you have on yours? (i've got just over 50 right now)
Have you tried a factory reset/reinstall?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let me know how it goes after the reset.
If that doesn't help, wait a bit. I'm on a little newer firmware version that I'm testing and maybe it fixed an issue with access control.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just updated for Firmware Version V1.0.8.70_2.0.36 and the issue is fixed now 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just curious as to how you got that FW version. Did your RAXE500 automatically download it? Mine is on a 1.0.7 version and the internal update check says there's no new version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A lot of time the auto-update server gets it first and even then, sometimes its only to a select few to ensure it functions properly. then it gets pushed to a larger release. I'm not showing it on the support site and mine was on a different firmware so I can't check the auto-update on mine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I went to check for new firmware it was available hope your gets the update soon
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to upgrade your FW to v1.0.8.70 to fix the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should upgrade your FW to v1.0.8.70 to solve this web issue, I just shot him and he did just fine. I tried both Edge and Google Chrome. How many devices do you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
