× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RX120 AX12 - Multi-gig port while in AP mode?
dkchum
Tutor
Hi all,
I am using my AX12 router in AP Mode, is there a way I can use the multi-gig port to get it to connect to my LAN? As it does not seem to pick up a IP when I plug in the cable to the multi-gig port and only works with the normal 1Gb ports.
thanks
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 4
Accepted Solutions
dkchum
Tutor
Re: RX120 AX12 - Multi-gig port while in AP mode?
I think I have found a soloution, I reset the AX12 back to 'Router' mode and setup the internet connection to use the 5G Port. Applied the settings, checked the internet was working and then changed the router back to 'AP mode'.
It is now using the 5G ethernet port to connect to my router.
Message 4 of 4
All Replies
microchip8
Master
not that i know of. also why are you using such a powerful router in AP mode?
Message 2 of 4
dkchum
Tutor
I use it with my Pfsense router that I built, to be honest is overkill for a home setup.
Message 3 of 4
dkchum
Tutor
Message 4 of 4
Discussion stats
  • 3 replies
  • 2972 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
