× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Rax 120-100NAS Reboot Problem
Harley55
Guide
I have a RAX120-100NAS running firmware 1.2.3.28. I noticed it reboots servel times a day. What's astable firmware to use or does anyone have a solution.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 22
Accepted Solutions
Harley55
Guide
Re: Rax 120-100NAS Reboot Problem
I checked the reviews of Netgear routes 120, 200, 500 and they all have a rebooting problem. Thanks for your help
Message 12 of 22
All Replies
Guru
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Message 2 of 22
Harley55
Guide
Spectrum EU2251 Firmware 2.76.2
Channels are set to Auto
Near by Spectrum nothing close by
Reset was done. Rebooted after setup.
Message 3 of 22
Guru
Does the router reboot if the WAN cable is not connected to the modem?
Might try downgrading FW to v24 and see if this continues or not. IF so, I would presume the router is faulty.
Message 4 of 22
Harley55
Guide
Right now I'm waiting to see if any changes happen after I did a total system reboot after everything was setup. It only reboots a few times a day since I installed it yesterday. I also have a Netgear R7000 that acted the same way. We found a older verison of the firmware that solved the problem. If the reboot doesn't solve the problem then I'll try the channels.
Message 5 of 22
Harley55
Guide
So far since I changed the 2.4 GHz to channel 1 it's been 12 hours and no reboot.
Message 6 of 22
Guru
Good to hear. Hopefully this will be the fix. Possible that the other channel is congested with nieghboring signals and causing problems.
Please mark your thread as solved so others will know.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
Message 7 of 22
Harley55
Guide
Is there a way to see in the router or else where to see the channels being used and by who?
Message 8 of 22
Guru
Most any wifi scanning or analytical app has features to see what wifi signals are being broadcast and what channesl they use. Most apps work best on pads vs phones.
Message 9 of 22
Harley55
Guide
Thanks for all your help but the router started to reboot again. It's going back defective today. I set up my Netgear R7000. Any suggestions on a good high end wireless router.
Message 10 of 22
Guru
Darn, possible the unit was just bad from the get go.Smiley Embarassed
Can try another 120 or maybe a RAX200. Any interest in a RAXE500? Something with 6Ghz support.
Message 11 of 22
Harley55
Guide
Message 12 of 22
Guru
Good Luck.
Message 13 of 22
Eric35
Guide
Where are the netgear-support to help us here?
About reboot problem i am almost 99% it's because of heat...
I tried to cool it down and no more reboot issue's
Message 14 of 22
Guru
Put a USB laptop fan under the router if you feel the router is getting too hot.
I keep one under any of my routers I have online 24/7.
Message 15 of 22
Eric35
Guide
Thanks for the tip.
I might try it even if i think this is not a good solution for the fture.
Message 16 of 22
Guru
I've been using USB laptop fans since about 2012 under my routers. No issues and helps save router HW from heat damage over time. Cooler the HW runs the better.
Message 17 of 22
Eric35
Guide
Good for you!!!
But read facts about it, all over internet / google and you'll see...
It's a good solution in short term.
Message 18 of 22
Harley55
Guide
Message 19 of 22
Guru
How solved?
@Harley55 wrote:
Message 20 of 22
derekcannady
Guide
I am also having the same issues, and have already had Netgear replace the router once.  The replacement does the same thing.  The router reboots  frequently soemtimes every 30 mionutes. I have noticed that the router reboots under heavy system load of +50% on the processor.  The only way I have been able to  lessen the issue is by turning off 2.4 Ghz WMM  services.  Unfortunately my 2.4 Ghz devices pay the price for that with slower  throughput. I can't even view some security camera streams any longer because the bandwidth is so poor. I am within the time period to return the router.  I'm hesitatnt to purchase the RAX200 because of the same issue.  I may have to try another brand after 10 years of using NG.
Message 21 of 22
Guru
Let us know if you can get the OP to post how they solved it...
@Harley55
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 4858 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
