- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rax Wifi set up
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rax Wifi set up
i has new ipad pro 2020 support wifi6, HT 80 mimo 4x4, I just bought rax200. My home ethernet lan is 1000/500 Mbps (my ipad far from router just only 5 m)
The problem is wifi speed not stable and not better than ac wifi, and sometime during speed test wifi sigmal disappear (speedtest app show error/failed test)
Please recommend how to set 5G-1 and 5G-2 to maximize wifi speed,
- Should uncheck 20/40 hz ?
- 5G-1 and 5G-2 set to 2400 or 4800 ?
- what chanel is the best
Thank you for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rax Wifi set up
Hello niwat,
If you recently purchased the device, I would suggest contacting our support team as your device is provided with 90 days of complimentary support. They will be able to assist in optimizing your settings for your network.
https://www.netgear.com/support/default.aspx
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
