× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax120 Nighthawk
andy73sg
Rax120 Nighthawk
Home network connection/setup doesn't work.
1) Router 1 (10Gbit/s capability, fiber-connected, XGS-PON technology):
-incoming fiber connection at 10 Gbit/s works
-WLAN works
-10Gbit ethernet port works
-Cable 1 (cat 7 ethernet) connection (from Router 1 to Switch) works
2) Switch (Netgear GS110MX):
-Cable 1 (cat 7 ethernet) plugged into port 9 (10G/Multi-Gig) works (two green lights blinking)
-Cable 2 (cat 7 ethernet) plugged into port 10 (10G/Multi-Gig) no lights blinking
-Cable 2 (cat 7 ethernet) plugged into home network cabling (cat 6e ethernet)
3) Router 2 (Netgear RAX120 Nighthawk) used as Access Point:
-Cable 3 (cat 6e ethernet) plugged into home network cabling (cat 6e ethernet) wall socket
-Cable 3 (cat 6e ethernet) plugged into port Multi-Gig (5G/2,5G/1G capable) no LED light blinking on Router
Question:
Why can't I connect GS110MX (10G/Multi-Gig) port via home network cabling to RAX120 (5G/2.5G/1G/Multi-Gig) port?
Connection 1G/Port at GS110MX via home network cabling to 1G/Port at RAX120 works (one green light blinking, only 100MB/s throughput?)...
Can somebody help, how I can at least get 5G/s from Router 1 via Switch and home network cable to Router 2?
Message 1 of 9
schumaku
Guru
Re: Rax120 Nighthawk
Reads like your installation is not properly set-up (for pairs/eight strands, correctly wired) for Gigabit and MultiGig. Only 100 Mbit/s negotiated  indicates that only two pairs are workable (or the cable isn't made for Ethernet at all, e.g. telephone cabling). And the Multi-Gig ports don't go down to Fast Ethernet.
Just curious - Salt/Switzerland?
Message 2 of 9
andy73sg
Cables are surely Ethernet.
„And the Multi-Gig ports don't go down to Fast Ethernet.“
Can you specify what this means?
Yes, Salt/Switzerland.
Message 3 of 9
schumaku
Guru
Blame me - both the GS110EMX and the RAX120 Multi-Gig port are "5-speed" so Fast Ethernet should be possible.
But still, if the supposed GbE link does negotiate to Fast Ethernet only ... something is potentially wrong with the cable installation. Was this installation intended for Ethernet, is the cable at least CAT5E or CAT6, or is this a former Telephone installation on T72 (the ol'Swiss PTT standard) wires?
Grüsse aus Kloten
-Kurt
Message 4 of 9
andy73sg
Thanks Kurt.
Cables are surely cat5e or higher (not Tel)...
Message 5 of 9
schumaku
Guru
Have no cable tester at hand I guess.... so check the connectors on both ends at least.
Message 6 of 9
andy73sg
Hi Kurt, you were right! Checked the cabeling and it turned out that it was a cat5e cabeling where 4 pins were split for Internet and the other 4 pins were split for Telefone. Had it corrected (4 pins from Tel to Internet). Now they communicate, although not at maximum speed due to cat5e. Thanks for the thoughts and ideas. Best! Andy
Message 7 of 9
schumaku
Guru
The classic cable saver tricks 8-) A clean CAT5E installation should allow the negotiation of 2.5 GbE, on shorter connections 5GbE often works even if this "formally" requires CAT6 ... however many better CAT5E cables reach and exceed the requirements of CAT6. A known Ethernet "killer" here in Switzerland are the POTS/ISDN RJ45 inserts with the screw terminals. You might have to replace the RJ45 wall plug inserts.
Message 8 of 9
andy73sg
realized that problem as well and have changed all relevant wall plug inserts. Thanks!
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3147 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
