- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rax120 firmware 1.2.0.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anybody else having these issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rax120 firmware 1.2.0.16
Yes, same problem in Italy. The firmware 1.2.0.16 does not allow Internet connection through devices connected to the router with the Ethernet cable, only Wifi works. Solved through a downgrade to the firmware 1.0.2.136
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a known issue, I would go to the support page and download the .16 then manually over a wired connection install the firmware then you must reset the router and setup as new.
that should solve your lan issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed that the latest version of RAX120; 1.2.0.16 has serious issues with WiFi connectivity. All the WiFi devices started complaining about Internet connectivity. It started all of a sudden (Jan 29, 2021). I tried resetting (pin-hole method) multiple times to no luck. Then I rolled back to v1.0.0.58 and then reset the router, and then upgrade to 1.0.2.136. After doing this, so far, my WiFi is stable with no issues since last 2 hours (the latest firmware issue comes up instantly upon upgrading).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe the RAX-120 is telling you something about Facebook :). I'm kidding.
My RAX-120 is doing the same thing but reading the threads will help. Thanks all.
