× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax120
Cal_mack
Rax120
Hello, I’m having a big issue with my PlayStation 5 which is connected via Ethernet cable. More often than not it disconnects my lab cable and connects it straight back afterwards, it will do this lots of times on some occasions.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 5
Guru
Re: Rax120
I'm really not sure what you mean by this.
What is actually happening in details?
What firmware are you on?
What modem/gateway is it connected to?
Message 2 of 5
Guru
Re: Rax120
Be sure your using good qualiity working LAN cables. CAT6 is recommended.
Message 3 of 5
Cal_mack
Re: Rax120
So the PlayStation will say lan cable disconnected, lan cable connected like it just drops the connection for a second then connects again. Sony have said it is a firewall setting within the router? I’m not too clued up with this stuff.
Thanks for your help!
Message 4 of 5
Guru
Re: Rax120
Have you tried replacing the ethernet cable?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 772 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
