- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rax200 will not inport wifi device from rax80
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rax200 will not inport wifi device from rax80
Hello Ronnie23,
That's exactly what you'll need to do after setting up the RAX200. Please go to every WiFi client within your home and forget the previous WiFi network and reconnect to the new WiFi network (RAX200).
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the technical explaination for these instructions? If the SSID and password of the old router are the same as the RAX200, why do we need to forget and re-add on every client?
Could this by why my RAX200 hasn't worked as described since purchasing it? Including the replacement that Netgear sent me?
No support tech in level 1 or level 2 ever gave the instructions that you are giving, Christian. If they are required, you should tell the higher-ups so that they can add it to the support scripts and instruction booklets and Nighthawk setup apps!
