× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Rax40 Setup
vancehurley5
Follower
Rax40 Setup
I literally need step by step instructions on how to setup this router from dtart to finish using the iphone app. I had it working and it will constantly lose internet connection. I have tried it plugged straight into the fiber, and plugged into another modem! PLEASE HELP!!!
Message 1 of 3
Guru
Re: Rax40 Setup
what fiber modem/gateway are you plugged into?
Who's your isp? some require specific settings to connect a router to.
What firmware is on the router?
The manual does have step by step instructions for installing using the browser.
https://www.netgear.com/support/product/RAX40.aspx
Message 2 of 3
Re: Rax40 Setup
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Start with the Quick Start guide.
Message 3 of 3
Discussion stats
  • 2 replies
  • 571 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
