× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ReadyCLOUD
markdlisle
Follower
ReadyCLOUD
Attempting to setup ReadyCLOUD, but the account creation web page is in a loop
please fix!
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Re: ReadyCLOUD
How are you trying to sneak up on ReadyCLOUD?
What happens when you try this?
ReadyCLOUD
or
ReadyCLOUD
No problems here. Both work fine.
Do they take you to some sort of brock wall?
@markdlisle wrote:
please fix!
Hard to do with so little detail of what you are doing and where it goes wrong.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Message 2 of 2
Discussion stats
  • 1 reply
  • 476 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
