× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
ReadyShare print utility seems to install, but does not work
tallguy98
Follower
I installed this new router (RAX80) and have issues trying to share printers via the USB connections.
DOwnloaded the ReadyShare Print utility, it SEEMS to install, but no devices show once the app is opened.
I read other posts about there being some settings that have to be disabled in order to get things installed, but no details about the "what" needs to be done.
Has anyone had this experience.  It says that version 1.36 of Readyshare was installed.
Thanks for any help you can share.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: ReadyShare print utility seems to install, but does not work
Hi tallguy98 - This has been reported in a prior thread. ReadyShare print is not a feature currently on the RAX80.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/AX6000-RAX-80-print-server-absent/...
~Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1893 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
