×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Recent RAX120 Firmware V1.2.0.16 rendered 2.4Ghz radios inoperable.
digitalis32
Tutor
On my RAX120 Router the 5G wireless works perfectly however the recent firmware update seems to have rendered the 2.4G radios inoperable. I have a considerable investment in IoT devices which rely heavily on this frequency band, and the loss of basic 2.4G connectivity from such an expensive device has been intesnely aggravating.
I have done a factory reset (base firmware was V1.0.2.136 ) and 2.4G is still inoperable, I have tweaked a few settings in the hopes of resolving any conflict with networks surrounding my house. I tried activating a guest network soley on 2.4Ghz which according to multiple devices that operate on that band was non-existant, the router persistently remains silent on that frequency.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 7
Guru
Re: Recent RAX120 Firmware V1.2.0.16 rendered 2.4Ghz radios inoperable.
you can downgrade the firmware. Maybe the new update caused issues.
Simply download the old firmware and follow the manual update process but use the older firmware
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 7
digitalis32
Tutor
Already done that, rolled back to the Base firmware and post downgrade I performed a reboot to ensure the device was reset properly.
Message 3 of 7
Chichizola
Star
Your best option is to drop Netgear and buy another brand, I did.
Message 4 of 7
thehypnootoad
Luminary
Honest I believe Netgear have given up on the rax line in general so many complains on here and reddit the only thing you can do is download firmware 1.0.2.136 make sure you dont have traffic meter on as plays havoc on connection. This sort of helps me for now but still loads problems especially with my smart devices on 2.4 I have to reserve the ip addresses and even use another ac network extender.
Message 5 of 7
digitalis32
Tutor
Thanks for the replies and assistance.
I did another factory reset, rebooted, installed new firmware (V1.2.0.16) and rebooted. And tediously rebuilt my settings (not from a saved config)
The resut was the 2.4G radios were again functional, but only for a while. I did my usual suite of stability and speed tests. The 2.4Ghz band cut out after 18 hours. After that, total radio silence on that frequency band. The 5G network functions perfectly and passed all the 24hr stress tests. So I'm back to the same problem as before.
I'm considering my options outside of the Netgear ecosystem. Irrespective of price point, there aren't many devices that provide the features that this one does.
Message 6 of 7
Chichizola
Star
Good desicion. I have to point out that this device does not provide the features, only advertices that it does. 🙂
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 948 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
