× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Replacement Power Supply
Kurt0375
Follower
Hi,
Recently got a use RAX200 but didn't come with a power supply, slight issue I have looked everywhere and can't seem to find a compatible power supply with the correct connector, I have found/ purchased a couple of different power supplies that say compatible with the RAX200 but the all have a central pin and are too small for the connection. United Kingdom
Any Ideas
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Replacement Power Supply
Hello Kurt0375,
I would recommend contacting the reseller of the device or you may try contacting our support team.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 3
FlatheadLake
Guide
Did you ever find a source for a DC plug eithout the center pin?
I need to replace the DC 7.4mm OD x 5.1mm ID (5.0 mm actual) barrel connector without a center pin that is on my Netgear Nighthawk CAX80 power supply.  Cannot find this plug anywhere and so far no help from Netgear support.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1268 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
