× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router AX12 RAX200 not conecting to internet anymore
jonnysbazar
ello guys got this modem July 6 2020 on amazon!The router is working, I can access the router login.. make changes,  but not connecting to the internet anymore! I have to get a new one to work again!But tried to open a ticket and your website told me to use the email so here we are!I want to fix it! how we can start the process? Thank you!
Message 1 of 6
Netduma-Liam
NetDuma Partner
Re: Router AX12 RAX200 not conecting to internet anymore
Thanks for posting!
You'll likely get better answers if you go ahead and post this in:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Message 2 of 6
Christian_R
NETGEAR Employee Retired
Hello jonnysbazar,
You may need to perform a factory reset your router by holding down on the reset button for 15+ seconds. You will need to run through the setup assistant again.
Christian
Message 3 of 6
jonnysbazar
Dit that buddy so many times! Got a router from other brand and works perfect!
3 router in 2 year buddy!
I don’t know why Netgear delivering routers with problems to people out there!
reset the router is pretty easy!
Very sad and mad that I spend so much for this and its not working anymore!
Message 4 of 6
TotalEnigma
Guide
I was having the same issue and no amount of factory resetting of the router or the CM2000 modem would fix it. I eventually went into the xFinity app and sent the modem a reboot signal from there. Once the modem came back online the router was able to aquire an IP address again and has been fine ever since.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 5 of 6
jonnysbazar
Hey buddy the modem that I use is from spectrum! and there is no chance that I can go online to the modem admin to make it work!
So since them I had to rent a router from them!
It sucks! but thanks anyway to help me out!
Message 6 of 6
Discussion stats
  • 5 replies
  • 779 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
