Orbi WiFi 7 RBE973
Reply
Router keeps rebooting
JoseMaka
Router keeps Factory resetting itself whenever rebooted. There's a new firmware and everytime I try to update it, it will get to the part of rebooting and then factory resets itself and needs to be setup all over again like it's a new router and then needs a update again.
Message 1 of 6
Re: Router keeps rebooting
How are you doing that? A manual update is the most reliable.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Disclaimer: Just another user with time on their hands.
Message 2 of 6
Guru
You have the RS700?
What firmware version are you on right now?
And then how are you updating? (as @michaelkenward says).
Thats key to. A manual method is best if you're having issues.
Message 3 of 6
JoseMaka
I'm updating via the nighthawk app and tried through the web browser also. It's running v1.0.7.86 it's saying the newest is v1.0.7.96. It resets itself everytime it reboots and for some reason at 3am also
Message 4 of 6
Guru
I recommend you make contact with NG support and ask about RMA options.
There's been a rash of some of these routers not accepting a FW update and persisting.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
@BH-C
Message 5 of 6
aiderS88
NETGEAR Expert
DM'd you. Please provide the requested info.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 615 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
