× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Satellites MS60 can't connect to MR60 with CH149
花开
Follower
I bought a WiFi6 Mesh router MR60 with 2 Satellites MS60 (FW: V1.0.6.102_2.0.45). When I use default wifi settings with CH42, Mesh connection can established successfully,. But when I change MR60's 5G channel to 149 in wifi setting, my two satellites can't connect to MR60, MS60's LED is always amber. I am sure CH149 is supported in China.
Message 1 of 2
Guru
Re: Satellites MS60 can't connect to MR60 with CH149
china does support channel 149. but not channel 144 or 151 which are next to it. So when the channel width is set to wide, those channels aren't available because of channel overlap.
List of WLAN channels - Wikipedia
Message 2 of 2
Discussion stats
  • 1 reply
  • 586 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
