× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Sudden loss of 5G1 and 5G2
nhnative
PC running Windows 10 64 Bit.  Updated to the latest firmware version.  Shut PC down one night and everything was fine.  When I started the following morning 5G1 and 5G2 were missing.  Spoke to provider and they have made no changes.  There have been a couple of Windows updates so I don't know if that may be the culprit.  I have done a factory reset with no change.  I did see 5G2 at one time but it said it was out of range.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 9
Accepted Solutions
Guru
Re: Sudden loss of 5G1 and 5G2
I like smart connect as it does band steering but some prefer their bands separated out. Glad to hear it fixed the problem. If you mark the answer as solved it'll help out the next person with this problem
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 9 of 9
All Replies
Guru
Is it only your windows pc experiencing the problem?
What wifi card are you using on the device with issues?
Do you have smart connect on?
https://www.netgear.com/support/product/r8000.aspx
Message 2 of 9
nhnative
Everything on my network is affected, including all PCs, smart phones, etc.   Smart Connect is on.
Message 3 of 9
Guru
What firmware is on it?
in version 1.0.4.28, the smart connect single ssid feature was added to all 3 bands. Maybe your router auto-updated and now all the bands are combined. It possibly defaulted to using the 2.4ghz ssid.
Message 4 of 9
nhnative
1.0.4.46
Message 5 of 9
Guru
So if you want them separated back out, you need to disable smart connect or downgrade the firmware.
Message 6 of 9
nhnative
Does it make any sense to do that?
Message 7 of 9
nhnative
I turned off Smart Connect and they came back as you said.  Thank you very much for you help.
Message 8 of 9
Guru
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3317 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
