- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Swapping from XFinity XFi to CM2050V / RAX200 drops my speed tests from 400+ to 100 ish
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have just swapped today from a XFinity XFi modem/router to a CM2050V / RAX200 combo. I did tests with several speed apps (inc FCC) and sites and consistently got over 400 Mbps. After the installs I get consistenly around 100. Both were 5g connections off the same PC and Phone in the same locations. How can this be fixed. I do not have Qos, Parental Control, etc on.
Any tips/advise welcome.
Thanks in advance Trevor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Swapping from XFinity XFi to CM2050V / RAX200 drops my speed tests from 400+ to 100 ish
what speed do you get hardwired into the router?
what device are you testing on wireless?
are you using the speedtest app on mobile?
how far from the router are you for testing.
What firmware are you on?
Are you using smart connect?
I've got a similar setup and can hit 600mbps on an older oneplus 6t with my RAXE500 over the 5ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thanks for responding so fast
I will test that speed later today as I am working; I have an Xfinity gigabit connection and was testing near that before the swap
two devices:HP Elite Book i7 Windows 10 and Samsung S20 Ultra
FCC, NightHawk and Xfinity apps, plus several website inc https://whatismyipaddress.com/speed-test
In office less that 40 feet from router
V1.0.3.106_1.0.58
Yes
Only one other person in house who does stream TV but not present and I am still only getting 200
Thanks
Trevor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure to test hardwired into the router and hardwired into the modem.
to many variables impact wireless speeds so lets start at basics and ensure full speeds at the modem and then at the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, will do,
I ma getting a slower speed hardwired also only just above wireless speeds - not what I expected.
I checked the pings and tracert and see the response times to the Xfinity gateway and DNS is slow (see piong and tracert stats below)
I will check with Xfinity as this is meant to be a gigabit connection.
ping 192.168.1.25 (local NAS)
Ping statistics for 192.168.1.25:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 8ms, Average = 3ms
C:\WINDOWS\system32>ping Xfinity Gateway IP
Ping statistics for Xfinity Gateway IP:
Minimum = 10ms, Maximum = 12ms, Average = 11ms
C:\WINDOWS\system32>tracert Xfinity Gateway IP
Tracing route to Xfinity Gateway IP over a maximum of 30 hops
1 2 ms 1 ms 1 ms 192.168.1.1
2 11 ms 10 ms 13 ms Xfinity Gateway IP
Trace complete.
C:\WINDOWS\system32>tracert 75.75.75.75 (Xfinity DNS server)
Tracing route to cdns01.comcast.net [75.75.75.75]
over a maximum of 30 hops:
2 13 ms 11 ms 19 ms xx.xx.xx.xx
3 14 ms 13 ms 12 ms 24.153.94.197
4 11 ms 10 ms 12 ms 162.151.39.237
5 13 ms 11 ms 12 ms 24.124.175.21
6 13 ms 11 ms 12 ms 68.87.170.14
7 13 ms 16 ms 12 ms dns-sw02.sandy.ut.utah.comcast.net [68.87.170.30]
8 10 ms 10 ms 16 ms cdns01.comcast.net [75.75.75.75]
Trace complete.
C:\WINDOWS\system32>ping 8.8.8.8 (google)
Ping statistics for 8.8.8.8:
Minimum = 23ms, Maximum = 28ms, Average = 24ms
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had an Xfinity engineer come out and test the spped which was up to par 800-1100 and using a Cat 6 connection to the Modem has good spped, but unless I am right next to the router I do not get more that 300 at best and mostly 100.
I guest it is just my house - anyhow 100 is good enough as I had move the route into my office and hardwired my office PC for work.
Thanks all.
