- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Terrible AX wifi speeds (ax12) with AX200 laptop
- Mark as New
- Bookmark
- Subscribe
- Permalink
1st off, I'm a 10 year systems admin, I have some knowledge here (not being cocky)
Laptop- Zenbook Duo Pro (ax200)
RAX120 router
XS505M 10Gbe switch
Z230 i7 16gb with Asus 10gbe network card and thunderbolt raid array
The desktop is connected to the switch (10Gbe), switch connected to mutilgig (5gb). I also have SSD connected in the USB 3.0 for further testing
I've updated drivers on all systems for their network cards
Verified all connections are at the correct speeds. Wifi is around 1.0Gbs to 1.7Gbs
My issue here is that my wifi speeds are terrible. I'm getting close to 50MBs when testing transfer speeds with iperf3 and just about the same with the SSD in the USB
-I've disabled QOS (WMM) but it made it so my wifi connection was 54MBs for a connection
-Iv disabled AX and at one point I got speeds to 145MBs but did a factory reset and reconfigured the router and now I'm back down to 50MBs
-I've factory reset multiple times, power cycled all hardware including fiber box.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Terrible AX wifi speeds (ax12) with AX200 laptop
aonavy1,
Thanks for taking the time to post. Would you mind providing us with the firmware version your router is currently on.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
for me i am having a different problem
the speed is good
but after 2 hours the actual net speed drop from 100 mb to 15mb or lower
and resetting either the wifi card or router solve it for 2 hours then i have to repeat again
- Mark as New
- Bookmark
- Subscribe
- Permalink
abogrhen,
Please try disabling the smart connect feature if you have it enabled.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah i think there is a communication problem between rax120 and ax200
i hope both sides Intel - Netgear can look into it
- Mark as New
- Bookmark
- Subscribe
- Permalink
I highly doubt you will get 200+ MB/s with any current router when paired with the AX200. I get around 140-144 MB/s on both ac mode and ax mode with the AX200, and with ax mode sometimes it will hit 160-170 MB/s but never sustained regardless of the RAX120 or RAX80. Similar results with others who tested on an Asus AX11000 which pretty much uses the same Broadcom chipset as the RAX80 plus an extra 5Ghz radio like the RAX200 has.
AX wont give you more than like a 10-20% realworld boost over ax on 5Ghz in raw speeds. Main advantage of AX over AC is performance in dense WIFi environments. On 2.4Ghz AX you can actually get 2x the performance when compared to 2.4Ghz N though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
On 2.4 Ghz you definately wont hit anywhere near even 100 MB/s. I hope you aren't confusing MB/s (Megabytes) with Mb/s (Megabits). 1 MB = 8 Mb, in networking Mb is the more common notation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
