× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Transfer speed awful on 160MHz with RAX120 and Intel AX200
powellandy1
Virtuoso
Hi
I have a RAX120 router (firmware 118) and an Intel AX200 card in my laptop.
When connected to channel 48 at 80Mhz I get file transfer speeds in explorer of 50-60Mbytes/sec.
Changed the router settings to channel 100 at 160Mhz (no nearby radar, router still shows channel 100 as does InSSIDer) and connect to network - file transfer speeds about 15Mbytes/sec.
Changed back at good transfer speeds again.
Any advice??
Cheers
Andy
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
NOiSEA
Guide
Re: Transfer speed awful on 160MHz with RAX120 and Intel AX200
I have the same problem - its been like this since I built the PC in February. I have tried 2 different AX200 160 MHz adapters. 1 is built into the motherboard and the other is a PCIe adapter made by ASUS but they both have the same problem. It seems to be a problem with the RAX120.
for a $500 router that is supposed to work with wifi 6, its amazing that it works with everything but wifi 6.
Can someone at Netgear please fix this problem?
Message 2 of 2
Discussion stats
  • 1 reply
  • 1454 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
