×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Tri band wifi 6e. Can I link 3 of these together in an Ethernet bridge mode
philipco
Follower
Options are 3 and eventually more nighthawk wifi 6e routers linked as Ethernet bridge devices
or move completely to nest devices
Message 1 of 3
Re: Tri band wifi 6e. Can I link 3 of these together in an Ethernet bridge mode
Sadly, that message means nothing to me.
Perhaps you could explain what your problem is, if you have one, and tell us which Netgear devices you are using.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
Are you trying to link 3x RAXE500's/RAXE300's together?
Are you trying to use an orbi?
What exactly are you trying to do?
the Orbi RBKE963 uses a router plus + 2x satellites with quad band (1x 2.4ghz, 2x 5ghz, 1x 6ghz) setup
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Discussion stats
  • 2 replies
  • 457 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
