Orbi WiFi 7 RBE973
Reply
UPnP broken in Netgear RAX80 on firmware 1.0.5.132_1.0.69
sachb
Tutor
I'm trying to forward some ports for my application, but unfortunately UPnP isn't working on all my devices connected to the Netgear RAX80 router.
I mainly use p2p application and seem to get this as my port status:
The same thing is happening on my mobile, where the app says that the portforwarding isn't active.
I think the UPnp is a bit slow to update, and doen't trigget port forwarding request immediately.
At one point it did show my computer with port needed to be forward, but it was still showing blocked on the app.
Kindly fix this issue, or else I'll have to look for older firmware or worse return the router for good.
If you have an older working firmware for port forwarding, do let me know.
Message 1 of 3
Guru
Re: UPnP broken in Netgear RAX80 on firmware 1.0.5.132_1.0.69
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NightHawk (WiFi6 RAX and RAXE Series) router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
Did you ever find a fix for the issue?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 716 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
