× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
URGENT: Network connect drops randomly
Jollymon
Tutor
Ever since I updated my network to a CM1150V modem and a RAX120 router I my connections on my computers drops during a web page load or a file download or application update. I am struggling to determine where the issue lies.
I am ready to dump all this Netgear hardware and go somewhere else.
I would appreciate and insight or ideas.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
thehypnootoad
Luminary
Re: URGENT: Network connect drops randomly
The firmware for the rax is poor and netgear don't seem to be taking issue on board are you on 1.0.2.16 if so drop back .1.0.2.136 do pin hole reset and try setup from new it doesn't fix all issues but its alot better. If not and can send it back I would get a asus.
Message 2 of 2
Discussion stats
  • 1 reply
  • 616 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
