× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
Rubikscube
Re: Unable to Access Advanced Tab in Routerlogin Portal After Firmware Update
Hey Andrew, were you ever able to get the issue fixed?
Message 26 of 40
lpayne-elliott
Model RAX 45
I would appreciate the trial firmware to fix the “advanced” tab issue.
Message 27 of 40
Guru
Please contact the forum moderator about this:
@DarrenM
@lpayne-elliott wrote:
Model RAX 45
Message 28 of 40
Foundtony
Tutor
What kind of device are you connecting through, a PC, tablet, laptop? I upgraded my AXE45 and had the same issue with the advanced tab. I discovered I couldn’t access advanced tab on my iPad Pro with any browser, but I could on my MacBook Pro using Google Chrome.
Message 29 of 40
syrock
Guide
@DarrenM
Model RAX 45
I contacted Darren via private message and have yet to hear back.
Message 30 of 40
syrock
Guide
I did find I can use chrome on my MacBook Pro to access the advanced tab. Still a larger issue with safari users. Hopefully Netgear is working on a permanent fix.
Message 31 of 40
Twitchrot
Star
Quick update the new firmware (V1.0.5.111_22.1.26) does fix the problem and you can access the Advanced TAB using Safari 15.3.  Hopefully this can be released for all soon.  Many thanks @DarrenM for letting us test in advance.
Message 32 of 40
Thawktogo
Would like to test upgrade firmware
Message 33 of 40
micbt25
@DarrenM wrote:
We have trial firmware with a fix for this issue please send me a PM if you would like to try this firmware.
DarrenM
When will it be rolled out, this has been going on entirely too long.
Message 34 of 40
Guru
NG doesn't post that information. You'll have to keep an eye on NG support download page or here in the forums.
If you want to try the beta, send @DarrenM a PM
Thank you.
@micbt25 wrote:
DarrenM
Message 35 of 40
micbt25
Thank you.
@micbt25 wrote:
DarrenM
Nevermind, this thing is going back to Costco. In 2 decades I've never had issues with new routers as I do with this one. In addition to the administration issues with not being able to view the advanced tab, the connection to the Internet drops off and I isolated that issue to the router not the 5g access point.
Message 36 of 40
DarrenM
Sr. NETGEAR Moderator
Please send me a PM if you would like to try Beta firmware that has a fix for this issue.
DarrenM
Message 37 of 40
amonynuts
Apprentice
This issue still occurs in the new RAX45 firmware release V1.0.10.110_2.0.75.  (Tested using Safari on iPhone8 with iOS 15.3.1)
Message 38 of 40
TeslaRMP
Same here. Updated to V1.0.10.110_2.0.75 and I still cannot access the Advanced tab on ANY device over Wi-Fi. Only an Ethernet connection will allow the advanced tab to work. Very annoying.
Message 39 of 40
Guru
Message 40 of 40
Top Contributors
Discussion stats
Announcements
Orbi 770 Series
