× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Unable to see 5ghz network
NightHawkUser8
I'm unable to view the 5ghz network that I've setup on my RAX45. I have the 5ghz network setup with a different name than the 2.4ghz one and I do not have Smnart Connect on. I also have SSID broadcast enabled for the 5 ghz network. When I view available networks on my laptop or phone, my 5ghz network is not listed. Any ideas as to why?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Re: Unable to see 5ghz network
Are you sure that these devices are 5 GHz capable? They won't see it if they can't use it? Do they work on 5 GHz anywhere else?
Is the RAX40 set to broadcast all SSIDs?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 833 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
