- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to update RAX80 Firmware, continued
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was asked to start a new threat, but I"m experiencing the exact same issue as this...
I've also tried everything suggested in the above thread.
Current Firmware Version 1.0.1.36
Router won't take new firmware.
I've tried macs, PCs, upgrading, downgrading, uploading through the web interface, selecting a local copy of the firmware, resetting through the web interface, resetting through the button on the back. Nothing works.
I am outside the support ticket window and premium support doesn't make sense for this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to update RAX80 Firmware, continued
@WowMeEvents wrote:I was asked to start a new threat, but I"m experiencing the exact same issue as this...
I've tried macs, PCs, upgrading, downgrading, uploading through the web interface, selecting a local copy of the firmware, resetting through the web interface, resetting through the button on the back. Nothing works.----what errors is it giving you? where is it failing? this helps more than just saying "it won't take". What's happening because we aren't there to see it. Take screen snips or better describe where/how/whats going on. There's multiple ways to update and describing how its failing in each is needed.
Helps me to help you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does not give me an error message.
It is not 'failing'. It goes through the update process like I assume it should, but at the end (after the reboot), the firmware still shows the same version.
From what I understand, there are only two ways to update firmware (which technically is 'multiple') - 'check' or 'browse'. Is there another?
I've tried both. Neither one actually updates the firmware. It looks like it's updating the firmware, but it doesn't actually update it.
I appreciate your help. What else can I tell you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which version are you trying to manually upgrade to?
Not auto-update. but manual.
where you download the firmware, extract it, and then install it.
Make sure to do it over a hardwired connection for the best results. I'd also recommend resetting the router before you start. reason why is youre on a version thats 6 versions out of date. so do a factory reset-then upload the firmware.
Page 99 in the manual walks you throught the update. Again, make sure to extract it. many make that error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I know you can't update with a zip.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes i was using a hard-wired connetion to the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try factory resetting and doing the install?
I'd also recommend taking an intermediate step. See if you can upgrade to version .56 instead of going all the way to .70
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rebooting screenshot.
I did reset it...software and hardware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
will it go up 1 version of firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Screenshot after the firmware update and reboot.
I've tried upgrading and downgrading.
In fact, I've tried every firmware version available on the site. None of them 'take'.
- Mark as New
- Bookmark
- Subscribe
- Permalink
try installing the firmware via tftp
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Make sure to enable tftp from within windows (if that's what you're on).
https://www.thewindowsclub.com/enable-tftp-windows-10
If that doesn't work, I'd go through the RMA process with netgear. You might be out of your 90 days free support but warranty should still cover it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It won't go up or down one version.
I also tried reinstalling the current version.
I didn't want to say it earlier because I didn't want to sound like an ass, but I build networks for a living, so I know how to upgrade firmware.
Did I mention I appreciate your help. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WowMeEvents wrote:It won't go up or down one version.
I didn't want to say it earlier because I didn't want to sound like an ass, but I build networks for a living, so I know how to upgrade firmware.-----I never assume anything because whenever I'm helping someone, sometimes its the little things. You'd be surprised how many times i get "the wifi isn't broadcasting and I've tried everything!" and it turns out to be someone pushed the wifi on/off button. 🙂
Did I mention I appreciate your help. 🙂-----Thanks!
I'd give the tftp method a shot. The RAX devices are pretty new and are having some growing pains with transitioning to new wireless standards. If it doesn't work, you should still be within the warranty
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried tftp multiple times and it looks like it's doing something, but then comes back with 'connect request failed'.
I also tried this way...
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
It looks like it's trying to start, but the progress window never appears.
I tried this on multiple ports on the router with the same result.
Every reset requires reentering my security questions. I'm growing real tired of that part of the process.
Any other ideas before I give up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Command Prompt Screen Shot with failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
the tftp you linked to was the client version.
did you follow this one?
and you enabled tftp? (that's key too)
as well as make sure you follow it exactly.
can you ping your router from the command prompt?
If you're able to log into it from the browser, it should be ping-able.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WowMeEvents, perhaps it would be helpful to use a Command Prompt window with administrative privileges for the tftp procedure?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know. I tried both.
Yes. That's the one you sent me and that's the one I tried first.
Yes
I did.
Yes
I can do both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Post 15 has a screenshot of the command prompt window showing error messages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any other ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should still be within warranty. You can try rma'ing it through support.
I've never had a router that you could boot and access into not be able to do tftp.
- Mark as New
- Bookmark
- Subscribe
- Permalink
During the process in the link above above...
7. Turn router OFF for 10 seconds.
8. Hold down the reset button on the back of router with a paper clip.
9. Power ON the router while holding down the reset button.
10. Watch the Power LED. It starts with an orange color, and then start flashing.
11. Count at least 10 flashing power LED and release the reset button.
As soon as I release the reset button, the router reboots. That's when I hit enter on the tftp command.
12. Press Enter to execute the TFTP command. Wait for a few minutes (be patient, do not reboot the router). When the upload is successful, the Power LED will turn solid. The rest of LED’s on the router will also turn ON indicating that the router has booted up properly.
So the tftp command is attempting to flash the firmware during a reboot? That doesn't make sense to me.
As another data point, after releasing the reset button in step eleven and the router reboots, the power light starts solid orange and does not ever blink. It finall turns white when the router is fully booted up.
Does any of that help? Because I don't have any of the paperwork for this one, so I doubt an RMA is possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try doing a 30/30/30 reset. what that is is this:
1. while powered on, push and hold reset for 30 seconds.
2. power it off all while holding reset. continue to hold for 30 seconds
3. power it back on while still holding reset. continue to hold for 30 seconds.
see if that factory resets it. Immediately after it boots. try downgrading the firmware 1 version or upgrading 1 version.
If that doesn't work, you can also try using nmrpflash.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you say 'Immediately after it boots', do you mean when the power light turns white, then press enter on the tftp command?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@WowMeEvents wrote:When you say 'Immediately after it boots', do you mean when the power light turns white, then press enter on the tftp command?
I mean after the 30/30/30. See if it actually resets to defaults. If it does, don't setup anything. Log into the router and then try the downgrade/upgrade process.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
