× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Update Breaks Advanced Tab
rbk-rax20
Initiate
Netgear AX1800 WiFi Router Model: RAX20
Updated today (2022-03-24) to Firmware Version V1.0.10.110_2.0.72 and now I cannot access the Advanced tab on the router setting page. I looked at the HTML source code to see if you could just grab the link and enter it into the address bar on my browser but there was no link.
<a id="advanced_label" ontocus="this.blur()"><span>ADVANCED</span> = $0</a>
See attached screen cap for more details.
Not sure if there is a way to get the link and just bookmark it or if there is quick fix for this issue. Any help would be appreciated.
Thanks.
edited to make code more legible.
Message 1 of 4
Guru
Re: Update Breaks Advanced Tab
What browser are you using? Happens with other browser?
Be sure to clear out all browser caches.
Try a factory reset and setup from scratch and see.
@DarrenM
Message 2 of 4
rbk-rax20
Initiate
Was using Safari, tested in FireFox and that was the fix. FFS Apple is killing me these days.
Thanks
Message 3 of 4
Guru
Thanks for letting us know.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1000 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
