× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
VPN access, but not all Internet is passing through
mnhim001
Hi,
My current router is a Netgear RAXE500.
I have VPN turned on and using OpenVPN to connect.  I have successfully connected to my home network using the VPN from work.  I am able to launch Gmail, which was blocked at my work.  I can access my home network drives while I am at work (connected to the VPN).
The only issue I have is when I try to connect to my Qnap NAS via myqnapcloud.com, I still get a "web page blocked" message telling me that its blocked.  Why is it not going through my VPN?  On the flip side, when I navigate to the NAS via IP, it goes through except its unsecure.
Any help appreciated.
Message 1 of 3
Razor512
Prodigy
Re: VPN access, but not all Internet is passing through
How is your VPN client configured?
Also do you have the VPN set to  "All sites on the internet & Home Network"?
If not, set it to that and generate a new config file.
As for the client device, some may enforce a different DNS server, and that can cause certain URLs to fail since the request will go out to the WAN rather than a local DNS server.
In some cases, if the OpenVPN client is not handling DNS correctly, you may need to manually specify one in the client config file by adding a line such as
dhcp-option DNS X.X.X.X
Where the specify an IP address (replacing those Xs) for a local DNS server on the home network that will handle those URLs properly.
As for untrusted connections, most NAS devices uses a self signed certificate for the HTTPS web UI, thus they will give an error like that.
Message 2 of 3
mnhim001
I do have "All sites on the internet & Home Network" selected.
I added my DNS (dhcp-option DNS X.X.X.X) into my OpenVPN configurations, this time instead of telling me that the web page is blocked, I now get "This site can't be reached".
I still can access it via IP address though.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 927 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
