× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
VPN on a RAX78 router
Kizziar
Well it's really a RAX78 but I wasn't offered that option and the rest of the discription fits.
Anyway this Netgear router actually has a VPN client option. First I've found on a Netgear router. But the only VPN service that appears in the drop down menu is PureVPN. I already have a VPN service (SurfShark) and am trying to figure out if there is a way to use it, SurfShark, on the RAX78. Netgear support didn't even know the RAX78 had a VPN client option so they were no help.
Anybody out there been able to change the VPN server on their like type router?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: VPN on a RAX78 router
Hello Kizziar,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 4
Kizziar
Hey Christian, thanks but they sent me to the community. It seems they didn’t know the Rax78 had VPN capability let alone if I could change the list VPN server.
Message 3 of 4
Christian_R
Hi Kizziar,
The RAX78 currently only supports OpenVPN. You may find more info on page 138 of the user manual linked below.
https://www.downloads.netgear.com/files/GDC/RAX70/RAX70_RAX78_UM_EN.pdf
Christian
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1409 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
