× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
VPN
Jakexx
VPN
Just puchased this router and I want to install aVPN  . Does it support  OpenVPN or L2TP VPN client configurations  ?   Thanx !
Message 1 of 12
Christian_R
NETGEAR Employee Retired
Re: VPN
Hello Jakexx - Would you mind providing us with the model number (eg. RAX80) of the router you recently purchased.
Thanks,
Christian
Message 2 of 12
Jakexx
Re: VPN
I have  a  Nighthawk AX3000  RAX 35
Message 3 of 12
Christian_R
Re: VPN
Hi Jakexx,
Thanks for confirming. Please check out page 107 of the user manual using the link below for more information on VPN features on the RAX35.
http://www.downloads.netgear.com/files/GDC/RAX35/RAX35_UM_EN.pdf
Christian
Message 4 of 12
schumaku
Guru
Re: VPN
@Jakexx wrote:
Does it support OpenVPN or L2TP VPN client configurations?
You intend to configure some hide-my-a**-type VPN client on the router for connecting it to some VPN provider e.g. in a different country or under a different legislation?
Christian, I fear this is not what the OP is looking for ...
Message 5 of 12
avtella
Prodigy
Re: VPN
Yeah, go to the suggestions section and vot for my third party VPN suggestion because, NG does not support anything other than PureVPN on the Nighthawks, not sure why we are forced to have this its not only one of the slower VPNs, they also been caught logging contrary to their claims.
Message 6 of 12
Jakexx
Re: VPN
Thanx ! I am considering returning it.  Any suggestions ?
Message 7 of 12
Jakexx
Re: VPN
I will go there !
Message 8 of 12
schumaku
Guru
Re: VPN
@avtella wrote:
...NG does not support anything other than PureVPN on the Nighthawks,...
Does the subject Nighthawk AX4 AX3000 4-Stream WiFi Router Model RAX35 suppor that at all?
Message 9 of 12
avtella
Prodigy
Re: VPN
You're right, I forgot about the lack of consistency in feature set between models, true not every model even has the built in option.
Message 10 of 12
Jakexx
Re: VPN
It doesnt cover it  on those pages
Message 11 of 12
Jakexx
Re: VPN
Christian, It does not cover how to install VPN's in the manual. Which leads me to believe it doesnt support them Which will make me return it
Message 12 of 12
Discussion stats
  • 11 replies
  • 1975 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
