× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Web Services Management is missing options.
Retired_Member
Not applicable
As title states, no options in web services management.
This is definitely some sort of firmware issue.
Firmware Version V1.0.5.132_1.0.69
What's going on here NetGear?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 4
Accepted Solutions
Guru
Re: Web Services Management is missing options.
NG seems to be moving away from Remote Management features and going to the mobile Nighthawk App for remote access. Were seeing this on other product lines as well.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Retired_Member
Not applicable
Thanks for the information. 🙂
Message 3 of 4
Deihmos
Guide
I had to downgrade the firmware to enable remote management because it was removed. They act like the barebone app can actually do anything useful.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1484 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
