Orbi WiFi 7 RBE973
Reply
Weekly Reboot after firmware update
Mitch_UpstateNY
I have an RAX20 / AX1800 router that was working just fine until I updated the firmware.  After that it started to need a weekly reboot. (I think someone introduced a memory leak).  Second firmware update didn't fix the bug.  Downgraded back to an older version of the firmware and it works just fine again.
1.0.2.82 - Solid, works great
1.0.3.96 - Needs weekly reboot
1.0.4.100 - Still needs weekly reboot.
Note: additional complaint.  Trying to fill out the "Start a New Discussion" form didn't have my model router listed in its models list.
Message 1 of 3
Accepted Solutions
Guru
Re: Weekly Reboot after firmware update
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 3
All Replies
Guru
Thank you.
Message 2 of 3
Mitch_UpstateNY
I did the factory reboot after dropping back to the older version.  I saw your suggestion that the factory reset may address the issue, so I did the update again and this time it appears to have updated without introducing the annoying weekly reboot.  The system has been running steadily for a month now so Thank You for suggesting the factory reset.  It appears to addressed the issue.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1454 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
