× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
What should I get to replace my r7000!
Fishon123
Follower
What would be a good replacement for the t7000
I thought about getting the AX8 but when I hooked it up it does not seem any faster than the AX8
Message 1 of 2
Re: What should I get to replace my r7000!
Answers will depend on what you are trying to achieve.
What's wrong with the R7000 that makes you want to change it?
What features are missing?
Where is its performance not as good as you would like?
Or do you just want a shiny new router?
Message 2 of 2
Discussion stats
  • 1 reply
  • 610 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
