× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Where can I purchase the RAX200 AC Adapter?
HIYOL
I bought RAX200 in Japan and want to use it in Korea, but the AC adapter is 100V-120V.
Since South Korea is 200V, I would like to purchase an AC adapter. Where can I purchase one?
Message 1 of 10
Accepted Solutions
Guru
Re: Where can I purchase the RAX200 AC Adapter?
NG doesn't sell power adapters separately.
This pulls up on Amazon: https://www.amazon.com/3-16A-Netgear-Nighthawk-RAX200-Power/dp/B019YU8N46
Message 4 of 10
All Replies
Guru
Maybe some regional places like Amazon or online etailer that may have them.
otherwise, may need to find a power converter maybe.
Message 2 of 10
HIYOL
Do you know where to buy genuine NETGEAR adapters?
By any chance, do you know the model number of the AC200V adapter?
Message 3 of 10
Guru
Message 4 of 10
HIYOL
Thank you!!
Message 5 of 10
Guru
Message 6 of 10
Jeffgear
Luminary
NG needs to sell a range of original power adaptors for its products for all regional variations, i.e. 110-220V, with different power pins.
There's a demand for these from users who buy from the global market place or from those who migrate and where the device is compatible with or configurable to local regulations.
Also the power adaptor is a component that's more likely to fail or get damaged in the home and it's not great doing a RMA for an entire system just to replace an adapter. It's also an easy component to eliminate when troubleshooting intermittent issues.
What's the best way to provide his feedback into their marketing executive?
Message 7 of 10
Guru
Message 8 of 10
Not really.
Netgear uses industry standard adaptors that work on many different devices.
It is easy to buy an inexpensive generic replacement. Do you really want to fight with Netgear's on-line store?
What Netgear needs to do is to give advice on what people need to look for.
A simple KnowledgeBase article with a physical and electrical specification is better than offering to sell something that costs several times the price of a generic brick/wall wart
You might find that third party alternatives are better than something cheaper that Netgear sticks in a box.
That would be a really useful "Idea Exchange".
Message 9 of 10
NO!
Netgear does not sell replacement power adapters. Any generic transformer will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions. (Look at the label on your device or the old adapter.)
These things are pretty common, so first check to see if you have something compatible lying around.
The good news is that the adapter that came with your RAX200 may well work.
For some odd reason, perhaps the law, most adaptors sold in the US specify "120 volts". In reality they are 120/240 V transformers.  (Some US adapters say that too.)
The adaptor will work fine in 240V if you have the right cheap mains adapters.
I have used quite a few 120V adaptors. (Netgear sends them out with beta stuff.) Not one has gone bang when plugged in.
You can just plug yours into the wall. If it doesn't blow up, it will work. If it does go bang, it is dead and won't harm your router.
Believe me, there is plenty of experience of this behaviour reported around her.
The idea that you buy a power converter is misleading and perverse.
Message 10 of 10
Discussion stats
  • 9 replies
  • 1513 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi 770 Series
