× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Where is NTP timezone setting on AX40? Sayd should be administrative area but nothing?
sonny_E
Guide
Message 1 of 12
Re: Where is NTP timezone setting on AX40? Sayd should be administrative area but nothing?
I assume that you mean RAX40. There is support for the RAX40, including manuals, at the end of this link:
>>> RAX40 | Product | Support | NETGEAR<<<
Get the manual and search for the section Set your time zone.
Message 2 of 12
sonny_E
Guide
Well, that is nice but in the manual on page 103 there is no option in the menu it points to.
Message 3 of 12
What are you trying to change? Server? Time zone?
It is clearly here:
  • Advanced
  • Administration
  • NTP Settings
in my router.
Different model, but it rarely moves, unless you have put the router into AP mode, in which case it is outside that device's control.
Message 4 of 12
sonny_E
Guide
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 5 of 12
sonny_E
Guide
firmware is V1.0.2.60_1.0.1
Message 6 of 12
Verbaetim
I can not find it either, it says in the manual but there is no NTP Settings my time is 1hr off, I am PST and its an hour earlier am in in AK time.
Hardware Version R1.05
Firmware Version V1.0.2.60_1.0.1
GUI Language Version V1.0.2.60_1.0.0.12
Select ADVANCED > Administration > NTP Settings.
The NTP Settings page displays.
5. Select your time zone from the menu.
6. If you live in a region that observes daylight saving time, select the Automatically
adjust for daylight savings time check box.
7. Click the Apply button.
Your settings are saved.
Message 7 of 12
sonny_E
Guide
Hopefully will be put back on the next firmware update. Obviously can adjust time schedules to counter this but should not need to.
Message 8 of 12
sonny_E
Guide
Could not log in with chrome out of the blue
Had new odd problem this morning. Could not log in with chrome and was told by the router to change my password? So did that and answered a couple questions had saved and would just Loop back to the start over and over. When I tried with the Microsoft Edge it was fine?
But Chrome now cannot use as I always did before.. Scanned my computer with Malwarebytes and Bitdefender and nothing found.
Message 9 of 12
Re: Could not log in with chrome out of the blue
This has got nothing to do with NTP timezones.
You are just another victim of this:
After Chrome v 77 update can no longer access my R... - NETGEAR Communities
Netgear is now on the case.
Message 10 of 12
sonny_E
Guide
Oh, got it. Thanks
Message 11 of 12
sonny_E
Guide
Glad to see the NPT settings are back. Under Advanced >security > schedule. Thx
Message 12 of 12
Discussion stats
  • 11 replies
  • 2709 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
