× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Why i can't disable the implicit beamforming on RAX120?
Peter_lgy
In the advance wireless configuration area of RAX120 , I can only enable or disable mu-mimo ..However for RAX80, I can enable or disable implicit  beamforming .
What does that mean?
On RAX120 ,the implicit beamforming have been canceled or must be enabled?
Who can tell me?
Thanks a lot?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Peter_lgy
Re: Why i can't disable the implicit beamforming on RAX120?
add the pic from rax80.
When i use RAX120,the option disappeared。
Message 2 of 6
Christian_R
NETGEAR Employee Retired
Hello Peter_Igy - Thanks for your post and a screenshot. You can find more information about Implicit Beamforming in the article linked below. Would you also mind providing the firmware version the RAX120 is currently on.
https://kb.netgear.com/25348/What-is-implicit-beamforming-and-how-do-I-enable-it-or-disable-it-on-my...
Thanks,
Christian
Message 3 of 6
Peter_lgy
Thanks Christian!
I have read the article you told me. Yes, other routers can disalbe the implicit beamforming such as RAX80. There do exist the check box. However on RAX120 NO.
So i am puzzled if RAX120 doesn't support implicit beamforming or just won't let the customers change the function?  Can you tell me? Thanks a lot!
The firmware i have updated to v1.0.1.90.
Message 4 of 6
Christian_R
Peter_Igy,
Sure thing! Beamforming is supported on the RAX120 however, there is no option to disable the feature in UI.
~Christian
Message 5 of 6
Peter_lgy
Thanks a lot, Christian!
I know beamforming is mandatory in 802.11ax.
So implicit beamforming is needless. Am I right?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2546 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
