- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi 5G dropping on RAX80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi 5G dropping on RAX80
Update!
The problem has not gone away. The router still looses 5G signal very 8-9 days (N still work). Lost it this morning made a reboot and will now count the days until I loose the signal again. As before a reboot fix the 5G signal.
/Johan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here ...
After some days, I can't connect to 5Ghz. Reboot solve the problem.
Is new firmware coming? I'll wait a bit but after that, i will resend it to Amazon !
- Mark as New
- Bookmark
- Subscribe
- Permalink
According to netgear, there is no issue.
There have been no firmware changes in the 6 months+ that I've owned the device that change anything except for adding localisation tweaks.
Give it back for a refund and choose another brand while you still can...!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update 2
I have also had problem with the speed on the ethernet connection from router to computer. Have a fiber connection 1000/100 and after a while it drops to circa 500 although the router speed check says circa 950 from provider to router. Tried to toogle QoS on and off - as suggested in the forum - get the correct/usual speed, circa 950, but the problem comes back after a couple hours or a day. Saw a another post on the forum that recommended to activate QoS and leave it on when you have the new firmware 1.0.2.76. Since I have had QoS enabled constantly last two weeks I get speeds between 600-900, and I have not (yet) lost 5G signal (I also use a local Swedish NTP server, not Netgear's).
/Johan
- Mark as New
- Bookmark
- Subscribe
- Permalink
But ... I am just waiting my new ax88u before send back my rax80 so...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone else having luck with the European .76 update?
I'm having fluctuated wifi signals - changed channels helped a little but now my 2.4g is wack.
Thinking of returning it if I can't fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well ignore that it's European (I just read from some other post that the update was for that region) - it's available if you do a search for it.
"RAX80 firmware" and the latest one is the .76 - and not the .70 which is what the device will say is the latest one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There was nothing in the release notes which would indicate improvements for smart connect, 5g/2.4g dropouts & several users posts that their lan issues weren't solved.
The same for all the other updates since 46 or 50.
They were all just minor tweaks for localisation.
I downloaded it just before the "work from home" rules were imposed so couldn't risk having something like this in my network to test it out.
However for me even if it did work, the complete lack of any kind of support or willingness to even acknowledge the issues from Netgear can only make me suggest sending it backwhile you can is the only sensible option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My problems were with .76 firmware from the beginning so i don't thing it will resolve yours issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like that this problem of 5G signals dropping is a permanent problem with this model. I have been trying to explain this to netgear support team since last 3 months and they support level is such a pathetic service that other than few useless tweaks, there is no genuine solution to the problem.
Even the replacement won't serve any purpose. I am regretting my decision of buying this useless model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In fact I have the feeling they knew about this all along & offered 90 days free support to make sure that you are outside of the return window by the time you recognise the support can't help you and there's no chance of any firmware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So true Man!!
It feels like we have been cheated by this brand which is never expected from them. I wish these messages ring a bell in the ears of some higher authorities to look into this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update 3
Today I lost my 5G signal again (worked appx three weeks). Made a reboot of the router trough the app (since N signal still works) and the 5G signal is back. Anoying...
/Johan
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm experiencing a more severe issue, I lose wireless and wired connections. After rebooting everything goes back to normal, only to be lost again after a few hours. the device becomes inaccessible so I cannot even view logs. After reboot, the logs are clear and you cannot view any historical data. I opened a case and they go through the same troubleshooting steps, I am now out of the warranty period so I'm stuck with a malfunctioning router that a year ago I paid $300+ for. This is insane, I don't think I will every buy another one of their products.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem resolved today - I elevate the router from the floor, plus contact support and they change the communication port to the last one. (116). Done!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My fault - I did it too fast...
- Go to Basic on your Router configuration
- On the 5G section, select:
- Channel 161 - Up to 1200Mbps
You will be ok Goodd luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used NetSpot on my mac to observe the wifi sgnal at 25' from my router and noticed frequent drop of 5G signal. Following are thje details:
1. 2.4G, Channel on Auto @1200
2. 5G, Channel 161 @2400
Trying to attach a screenshot of 5G dropping signal which recovers in a minutes time.Any idea why it happens only on 5G signal whereas 2.4G remains steady.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I switched back to ch 161@2400 mbps and speed came back to 220mbps and so far no 5G signal drop.
Conclusions:
1. There is something definitely wrong with hardware or software of this router that it starts dropping 5G WiFi at regular intervals.
2. You get best speed at ch 161@2400mbps
3. In case router is misbehaving, it may be worth setting 5G setting to ch 161@1200mbps and then revert back to ch 161@2400mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will do that change and confirm the results.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
