× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Wifi not found by new laptop device. Every other device sees and can connect.
brossi19
My son's new school issued Dell chromebook  does not find our home netgear wifi. It does see other local wifi devices and routers nearby. Every other type of devise from cell phones, ipads, pcs, laptops , roku, printers, smart tvs, etc. all find and connect to our home wifi with no problem. Can anyone suggest a solution. The school's IT dept says it a router issue after replacing the chromebook 3 times with the same results. Other kids chromebooks connect with their home routers.
Thanks,
Brian
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Accepted Solutions
myersw
Master
Re: Wifi not found by new laptop device. Every other device sees and can connect.
You have an AX router. If AX is enabled try turning it off. Not all devices play well with AX being available at this time. Odds are you do not have and AX clients anyway.
Message 2 of 4
All Replies
myersw
Master
Message 2 of 4
brossi19
God bless you!   You  are awesome. That was exactly it!  Problem solved!
Message 3 of 4
myersw
Master
Glad the suggestion got you working and kid can do his school work.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2004 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
