Orbi WiFi 7 RBE973
Reply
Wifi6
Retired_Member
Not applicable
Wifi6
I just got an iPhone 12 pro and the download speed is faster than before but in the connections it shows wifi 5???
Message 1 of 7
microchip8
Master
Re: Wifi6
You don't say which router model you have.
Message 2 of 7
Retired_Member
Not applicable
Re: Wifi6
Sorry that's the confusion it's not in the drop down box but it's a AX6 6-Stream AX5400 WiFi Router(RAX50S)
Message 3 of 7
microchip8
Master
Re: Wifi6
Do you have seperate SSIDs for each band? If so, does your iPhone see the 6 GHz/SSID band?
Message 4 of 7
Retired_Member
Not applicable
Re: Wifi6
No, the auto feature has worked fine before but this is the first AX device.
Message 5 of 7
microchip8
Master
Re: Wifi6
if by auto feature you mean Smart Connect? If so, NG's implementation is rather buggy. Many times it is often better to have seperate SSIDs
Message 6 of 7
Retired_Member
Not applicable
Re: Wifi6
Yes I agree the software is "rather buggy" and the app is unacceptable, but why doesn't Netgear make necessary corrections so we do not have to do inconvenient workarounds. Thank you for your answer, but wouldn't it be Netgear responsibility to look into this? That is why they have NO direct way to message them.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1678 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
