× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
X6 (R8000) - AC3200 - Sporadic Wifi speeds
wonderbison
Tutor
Hi
About 3 weeks ago I guess my Wifi started being very sporadic in its speeds. Sometimes 30MB sometimes 341MB download. No settings were changed etc. Updated to latest firmware, no luck. Factory reset completely and still the same sporadic.
"Hardare support" is the sum of "you're lights are flashing and so your hardware is fine". I dont believe its a setting otherwise I would have seen this when I first bought the product. I see this occurring on all 3 bands.
Guest networks are disabled
WAN settings, all unselected except Disable IGMP proxing
QoS off
WMM all enabled
Anything else that might be of interest that might help?
Any help appreciated
Thank you all
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 8
Accepted Solutions
Guru
Re: X6 (R8000) - AC3200 - Sporadic Wifi speeds
2 things you could try.
(try 1 then the other)
1. try installing version 1.0.4.28 of the firmware to the R8000. Then do a factory reset and a clean install (not from backup). disable auto-updates. the newer versions integrated netgear armor and not all r8000's played nicely with it.
2. try the virgin router in router mode and the r8000 in access point mode. Maybe its passthrough mode is sketchy
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 6 of 8
All Replies
Guru
What actual firmware version are you on?
what modem are you connecting to?
Are you using smart connect?
Smart connect band steers devices between 2.4ghz and 5ghz as needed. and 2.4ghz is very slow in comparision to 5ghz.
Have you noticed if its specific devices?
Do hardwired devices see a decrease in speeds?
Message 2 of 8
wonderbison
Tutor
Hi
Thanks for replying.
What actual firmware version are you on? - V1.0.4.66_10.1.75
what modem are you connecting to? - VirginMedia SuperHub
Are you using smart connect? No
Have you noticed if its specific devices? Its all devices, iPad, Android OnePlus phone (3 of), desktop computer with Gigabit Ethernet card, laptop (generic wireless card I think)
Do hardwired devices see a decrease in speeds? I dont have anything hardwired but when I did when testing albeit over a short period of an hour or so, there was no issues.
As an aside I thought it was maybe channel interference but they are all reporting as Good on the channels assigned
5G is 36+40+44(P)+48
5G-2 is 100(P)+104+108+112
Thank you
Message 3 of 8
Guru
virgin superhubs are modem router combo devices.
which specific one do you have?
Is it in passthrough/modem only mode?
https://kb.netgear.com/30186/What-is-Double-NAT
Message 4 of 8
wonderbison
Tutor
Hi
which specific one do you have?  - I have Hub 3.0
Is it in passthrough/modem only mode? Yes it is modem only mode with DOCSIS
Standard specification compliant DOCSIS 3.0
Hardware version 10
Software version 9.1.1912.304
Thanks
Message 5 of 8
Guru
Message 6 of 8
astones
I had a similar issue to this.  Is there a fix coming in the firmware?
Message 7 of 8
wonderbison
Tutor
Hi
I had to use option 2 route. And I am now getting the best Wifi speeds I have seen.
I will update the firmware later on and re-check but certainly option 2 seems to have been the most stable for me
Thank you
Message 8 of 8
Discussion stats
  • 7 replies
  • 1598 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
