× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XAR40 Wireless conection issues
Igonzaloo
Follower
I connected my new router with the Ethernet cable to my modem and when I try to go the internet it doesn’t work , this is the second I’m getting because the first one it said that the Ethernet cable wasn’t connected . And now I have all green lights but still hasn’t be able to connect to the internet. I already rebooted the router I don’t know if it’s the modem that is not comptable or something. I have internet because I connected it to my laptop using the cable and the problem is the WiFi .
Thank you
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: XAR40 Wireless conection issues
Hello Igonzaloo - If you recently purchased the router, I would recommend contacting our Support Team:
https://www.netgear.com/support/default.aspx
~Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1756 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
